[postgis-devel] Some sort of memory leak?
Paul Ramsey pramsey at cleverelephant.ca
Mon Dec 15 10:32:26 PST 2008
Mark, what's your vote on 1.3.5 ASAP as of now?
P
On Mon, Dec 15, 2008 at 5:07 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> Okay I guess there are still quite a few crashers in the curve support
> section, so I took those tests out.
> Attached is torture test minus the circular tests and minus the new
> functions (ST_IsValidReason, ST_Populate_Geometry_Columns)
> +1 for me as far as releasing a 1.3.5 assuming no one runs into any
> crashes doing the above.
> or notices anything questionable in the output.
> Thanks,
> Regina
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
