[postgis-devel] Issue 86 in postgis: ST_LineToCurve produces invalid curves
codesite-noreply at google.com
Wed Dec 17 03:26:00 PST 2008
Comment #1 on issue 86 by mark.cav... at siriusit.co.uk: ST_LineToCurve
http://code.google.com/p/postgis/issues/detail?id=86
I think the key to this is that the generated CURVEPOLYGON is actually
invalid. When
trying to parse the geometry using SVN trunk, I get a "parse error - invalid
geometry" message which points to a parse failure at character 104 which
looks like this:
CIRCULARSTRING(2.47032822920623e-323
5.32506451083601e-315,4.31693359794991e-308
-2.51624134379182e+307,nan ...
Hmmm. So it looks like the parser (possibly correctly) is choking on the
NaN. My
guess would be the CIRCULARSTRING generation code should not output this
value rather
than the parser being altered to accept it?
HTH,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
