[postgis-devel] SVN trunk strange regression failures
Paul Ramsey pramsey at cleverelephant.ca
Wed Dec 17 12:25:28 PST 2008
Same behavior observed here. Patch applied, behavior improved.
Committed at r3438. Only regress failure is regress_bdpoly,
On Wed, Dec 17, 2008 at 12:08 PM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Hi folks,
> While testing the last fix committed to SVN, I decided to blow away my copy
> of trunk and re-check out everything from the SVN server. Now for some
> reason, I get the attached diff in the regression tests - or in other words,
> some stray LFs have gotten into the expected.in files.
> Does anyone else see this from a fresh checkout? And if so, does anyone mind
> if check in the attached to return the tests to normality? (NOTE: 1.3 branch
> works fine, it just seems to be trunk).
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
