[postgis-devel] Updates to GEOS & POSTGIS
Paul Ramsey
pramsey at refractions.net
Mon Jan 21 14:11:06 PST 2008
I'm not sure that will work, since the symbols for the new functions
will be missing in the older versions... might we not end up with a
link-time error? The thing about the GEOS stubs is that they are
wrapped in a USE_GEOS define that removes the library dependency.
P
On Jan 21, 2008, at 1:24 PM, Ben Jubb wrote:
> Ill implement your first suggestion, and stub the C functions for
> the prepared stuff, moving the version detection to the
> lwgeom_geos_c.c. Seems friendliest to the long suffering VS users.
> b
> Paul Ramsey wrote:
>> Historically, we've left sql.in along and put in stubbed functions
>> in the .c files, in the case of with-GEOS versus without-GEOS. We
>> could go whole hog and add GEOS version detection to ./configure.
>> Might make things even worse for VCC workers.
>> As of now, having trolled the code base, there is a geos_version.sh
>> script which can write the version into a #define for use
>> elsewhere. The only running code that works with version is the
>> run-time version print-out in postgis_geos_version().
>> The most elegant thing would be to put it into ./configure, IMO,
>> but I'm not sure that's the most *useful* thing.
>> P
>> On Jan 21, 2008, at 11:45 AM, Ben Jubb wrote:
>>> My changes won't build against the GEOS 3.0.0 branch. use the
>>> trunk instead.
>>> I'm open to suggestions as to how to get the GEOS version
>>> information into lwpostgis.sql.in.
>>> cheers
>>> b
>>> Mark Cave-Ayland wrote:
>>>> On Fri, 2008-01-18 at 09:26 -0800, Ben Jubb wrote:
>>>>> Mark,
>>>>> thanks for the comments,
>>>>> - I'll change the comment style..
>>>>> - added the initGEOS() calls, oops..
>>>>> - the size calculation: ill try your suggestion for getting
>>>>> arg1_length.
>>>> Hi Ben,
>>>> I've just done a checkout of latest SVN, and unfortunately it seems
>>>> broken against the GEOS 3.0.0 branch :(
>>>> I managed to get around the compilation failures by removing the
>>>> line
>>>> "#define PREPARED_GEOM 0", but regression tests fail because
>>>> lwpostgis.sql.in still references these functions, and hence it
>>>> fails to
>>>> load into PostgreSQL.
>>>> So in order to support both newer and older versions of GEOS, there
>>>> needs to be some GEOS versioning directives around the new code
>>>> in both
>>>> lwpostgis.sql.in and lwgeom_geos_c.c (rather than having to alter
>>>> both
>>>> of these by hand).
>>>> ATB,
>>>> Mark.
>>> <benjubb.vcf>_______________________________________________
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
