[postgis-devel] Updates to GEOS & POSTGIS
Ben Jubb
benjubb at refractions.net
Mon Jan 21 14:45:08 PST 2008
I wrapped the bodies of the new functions I added to lwgeom_geom_c.c
with an #if test for the right version of the GEOS lib, along with an
#else part that throws a 'not implemented' error. This particular
source file is definitely dependent on the GEOS library. If the older
version of GEOS is used, the 'prepared' functions will throw an error.
I don't think this will cause a link error.
Im not sure what you are refering to as 'GEOS stubs'.
b
Paul Ramsey wrote:
> I'm not sure that will work, since the symbols for the new functions
> will be missing in the older versions... might we not end up with a
> link-time error? The thing about the GEOS stubs is that they are
> wrapped in a USE_GEOS define that removes the library dependency.
> P
> On Jan 21, 2008, at 1:24 PM, Ben Jubb wrote:
>> Ill implement your first suggestion, and stub the C functions for the
>> prepared stuff, moving the version detection to the lwgeom_geos_c.c.
>> Seems friendliest to the long suffering VS users.
>> b
>> Paul Ramsey wrote:
>>> Historically, we've left sql.in along and put in stubbed functions
>>> in the .c files, in the case of with-GEOS versus without-GEOS. We
>>> could go whole hog and add GEOS version detection to ./configure.
>>> Might make things even worse for VCC workers.
>>> As of now, having trolled the code base, there is a geos_version.sh
>>> script which can write the version into a #define for use
>>> elsewhere. The only running code that works with version is the
>>> run-time version print-out in postgis_geos_version().
>>> The most elegant thing would be to put it into ./configure, IMO, but
>>> I'm not sure that's the most *useful* thing.
>>> P
>>> On Jan 21, 2008, at 11:45 AM, Ben Jubb wrote:
>>>> My changes won't build against the GEOS 3.0.0 branch. use the
>>>> trunk instead.
>>>> I'm open to suggestions as to how to get the GEOS version
>>>> information into lwpostgis.sql.in.
>>>> cheers
>>>> b
>>>> Mark Cave-Ayland wrote:
>>>>> On Fri, 2008-01-18 at 09:26 -0800, Ben Jubb wrote:
>>>>>> Mark,
>>>>>> thanks for the comments,
>>>>>> - I'll change the comment style..
>>>>>> - added the initGEOS() calls, oops..
>>>>>> - the size calculation: ill try your suggestion for getting
>>>>>> arg1_length.
>>>>> Hi Ben,
>>>>> I've just done a checkout of latest SVN, and unfortunately it seems
>>>>> broken against the GEOS 3.0.0 branch :(
>>>>> I managed to get around the compilation failures by removing the line
>>>>> "#define PREPARED_GEOM 0", but regression tests fail because
>>>>> lwpostgis.sql.in still references these functions, and hence it
>>>>> fails to
>>>>> load into PostgreSQL.
>>>>> So in order to support both newer and older versions of GEOS, there
>>>>> needs to be some GEOS versioning directives around the new code in
>>>>> both
>>>>> lwpostgis.sql.in and lwgeom_geos_c.c (rather than having to alter
>>>>> both
>>>>> of these by hand).
>>>>> ATB,
>>>>> Mark.
>>>> <benjubb.vcf>_______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080121/e7774233/attachment.vcf>
