[postgis-devel] Issue 42 in postgis: Postgis Docbook CSS upgrade
Dane Springmeyer
blake at hailmail.net
Mon Jul 14 14:16:50 PDT 2008
Thanks Paul,
And here's an html version for reference: http://danespringmeyer.com/tmp/postgis_alt_css.html
Looks like the background colors do not come through for the <code>
<pre> and <note> tags in the pdf version (if that is desirable I'll
need to look into why that is...)
Dane
On Jul 14, 2008, at 1:47 PM, Paul Ramsey wrote:
> Looks good to me. Not hearing any objections, I'll swap this in
> shortly. I've attached a PDF of hte output for those who want to see
> without testing themselves.
> On Mon, Jul 14, 2008 at 1:29 PM, <codesite-noreply at google.com> wrote:
>> Issue 42: Postgis Docbook CSS upgrade
>> http://code.google.com/p/postgis/issues/detail?id=42
>> New issue report by dane.springmeyer:
>> With the various enhancements and efforts going into the PostGIS
>> documentation currently, I think
>> the CSS could use an upgrade as well.
>> The main room for improvement I see in the CSS/formatting is the
>> handling of
>> code examples and
>> notes. If these distinct sections (which are being expanded
>> currently) were
>> more distinctly formatted
>> with color or background it would help the readability of the docs.
>> I've attached a patch and the corresponding file for an alternate
>> css that
>> fits my taste. I offer it
>> purely as an alternative or a starting point. I noticed the recent
>> addition
>> of blue and orange
>> branding of the official Postgis Refractions site and therefore
>> pulled from
>> those colors a bit.
>> Suggestions to improve it are welcome, and if it is acceptable to the
>> developers integration into the
>> codebase is fine.
>> style.css 2.5 KB
>> style.diff 3.2 KB
>> Issue attributes:
>> Status: New
>> Owner: ----
>> Labels: Type-Defect Priority-Medium
>> You received this message because you are listed in the owner
>> or CC fields of this issue, or because you starred this issue.
>> You may adjust your issue notification preferences at:
>> http://code.google.com/hosting/settings
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> <PostGIS 1.3.4
> Manual.pdf>_______________________________________________
