[postgis-devel] Issue 42 in postgis: Postgis Docbook CSS upgrade
Paul Ramsey pramsey at cleverelephant.ca
Mon Jul 14 13:47:07 PDT 2008
Looks good to me. Not hearing any objections, I'll swap this in
shortly. I've attached a PDF of hte output for those who want to see
without testing themselves.
On Mon, Jul 14, 2008 at 1:29 PM,  <codesite-noreply at google.com> wrote:
> Issue 42: Postgis Docbook CSS upgrade
> http://code.google.com/p/postgis/issues/detail?id=42
> New issue report by dane.springmeyer:
> With the various enhancements and efforts going into the PostGIS
> documentation currently, I think
> the CSS could use an upgrade as well.
> The main room for improvement I see in the CSS/formatting is the handling of
> code examples and
> notes. If these distinct sections (which are being expanded currently) were
> more distinctly formatted
> with color or background it would help the readability of the docs.
> I've attached a patch and the corresponding file for an alternate css that
> fits my taste. I offer it
> purely as an alternative or a starting point. I noticed the recent addition
> of blue and orange
> branding of the official Postgis Refractions site and therefore pulled from
> those colors a bit.
> Suggestions to improve it are welcome, and if it is acceptable to the
> developers integration into the
> codebase is fine.
>        style.css  2.5 KB
>        style.diff  3.2 KB
> Issue attributes:
>        Status: New
>        Owner: ----
>        Labels: Type-Defect Priority-Medium
> You received this message because you are listed in the owner
> or CC fields of this issue, or because you starred this issue.
> You may adjust your issue notification preferences at:
> http://code.google.com/hosting/settings
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Name: PostGIS 1.3.4 Manual.pdf
Type: application/pdf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080714/8a647ecf/attachment.pdf>
