[postgis-devel] Docbook ID's and <a name> links
Kevin Neufeld
kneufeld at refractions.net
Tue Jul 15 11:34:59 PDT 2008
Regina,
> I mean a second TOC listing. I like them being together but since they
> are such an important
> SQL concept, I think they deserve redundancy in the TOC.
> Well I was hoping that there would be some automagic way to pull out any
> entry with
> Geometry set (or should it be geometry set)
> Hmm - also are we going with upper on Geometry or geometry. I just
> realized we have both variants because the template.xml has upper case,
> but we've always used lower case.
Yeah, I agree it should be lower case to match the other PostgreSQL
datatypes.
> If there is no automagic way - its not that big a deal since we don't
> add aggregate functions that often. We can fill that in afterward.
> Thanks,
> Regina
I'm not aware of any way to automatically generate a second TOC using
specific ids ... except maybe by generating an index, but that's quite
different. Does anyone else have ideas how DocBook could do this?
I agree that we can tackle this afterward.
Cheers,
Kevin
