[postgis-devel] ST_AsKML Update
Paul Ramsey
pramsey at cleverelephant.ca
Fri Mar 28 14:40:39 PDT 2008
I've applied this to trunk, with a couple changes to get it to compile
and properly obey macros in the overall build environment.
On Sat, Mar 22, 2008 at 1:05 PM, Eduin Carrillo <yecarrillo at yahoo.com> wrote:
> This is an update for ST_AsKML. I'm including minor changes to sync with ST_AsGML to correct errors in a previous patch.
> Changes:
> - Changes to get sync with latest changes in GML producer
> - Renamed AsUKML() to _ST_AsKML() as internal pointer to LWGEOM_asKML
> - Removed all references to ST_AsUKML() (They should never have exist)
> - KML functions are now created only if Proj4 support is enabled
> NOTE: version parameter to ST_AsKML() is enabled but unused and
> therefore it is undocumented.
> Eduin Yesid Carrillo Vega
> Ingeniero Civil, Universidad Industrial de Santander UIS
> Laboratorio de Biogeografía y Análisis Espacial
> Instituto de Investigación de Recursos Biológicos Alexander von Humboldt
> yecarrillo at humboldt.org.co
> Cr.13 28-01 P.7
> Tel. (+57 1) 3506064 ext 122
> Bogotá D.C., Colombia
> ____________________________________________________________________________________
> ¡Capacidad ilimitada de almacenamiento en tu correo!
> No te preocupes más por el espacio de tu cuenta con Correo Yahoo!:
> http://correo.espanol.yahoo.com/
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
