[postgis-devel] ST_AsKML Update
Eduin Carrillo
yecarrillo at yahoo.com
Sat Mar 22 13:05:45 PDT 2008
This is an update for ST_AsKML. I'm including minor changes to sync with ST_AsGML to correct errors in a previous patch.
Changes:
- Changes to get sync with latest changes in GML producer
- Renamed AsUKML() to _ST_AsKML() as internal pointer to LWGEOM_asKML
- Removed all references to ST_AsUKML() (They should never have exist)
- KML functions are now created only if Proj4 support is enabled
NOTE: version parameter to ST_AsKML() is enabled but unused and
therefore it is undocumented.
Eduin Yesid Carrillo Vega
Ingeniero Civil, Universidad Industrial de Santander UIS
Laboratorio de Biogeografía y Análisis Espacial
Instituto de Investigación de Recursos Biológicos Alexander von Humboldt
yecarrillo at humboldt.org.co
Cr.13 28-01 P.7
Tel. (+57 1) 3506064 ext 122
Bogotá D.C., Colombia
____________________________________________________________________________________
¡Capacidad ilimitada de almacenamiento en tu correo!
No te preocupes más por el espacio de tu cuenta con Correo Yahoo!:
http://correo.espanol.yahoo.com/
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080322/27c87177/attachment.obj>
