[postgis-devel] Roadmap for next major release of PostGIS
Tom Lane
tgl at sss.pgh.pa.us
Wed May 28 07:43:38 PDT 2008
Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk> writes:
> - Rewrite the regression test harness
> The regression test harness is currently written as a shell script,
> which makes running regression tests under Win32 only possible under
> MingW. In order to support an MSVC build, it is intended to re-write the
> regression test script in Perl (which is required to build PostgreSQL
> under MSVC).
Have you looked into using the current incarnation of pg_regress?
It works fine under MSVC.
regards, tom lane
