[postgis-devel] Issue 68 in postgis: ST_Shift_Longitude doesn't work with MULTIPOINT
codesite-noreply at google.com
Tue Nov 4 12:28:25 PST 2008
Issue 68: ST_Shift_Longitude doesn't work with MULTIPOINT
http://code.google.com/p/postgis/issues/detail?id=68
New issue report by robe.... at cityofboston.gov:
What steps will reproduce the problem?
1. SELECT ST_Shift_Longitude(ST_GeomFromText('MULTIPOINT(1 3, 4 5)'))
Gives error
ERROR: lwgeom.c:723: unknown geom type: 4
********** Error **********
SQL state: XX000
--However this works fine - isn't MULTIPOLYGON more complex
SELECT ST_Astext(ST_Shift_Longitude(ST_GeomFromText('MULTIPOLYGON(((1 3,4
5,3 4,3 4.5,1 3)))')))
Also doesn't work with Circular string - gives similarly cryptic message
SELECT ST_Shift_Longitude(ST_GeomFromText('CIRCULARSTRING(1 3, 4 5, 6 7)'))
ERROR: lwgeom.c:723: unknown geom type: 8
I just tried on newest 1.3.4SVN snapshot and 1.3.3. Gives same error on
both.
Issue attributes:
Status: Accepted
Owner: robe.... at cityofboston.gov
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
