[postgis-devel] Issue 67 in postgis: new tablespace parameter for shp2pgsql
Kevin Neufeld
kneufeld at refractions.net
Wed Nov 5 07:58:23 PST 2008
Very true. Thanx for that insight Mark,
-- Kevin
codesite-noreply at google.com wrote:
> Issue 67: new tablespace parameter for shp2pgsql
> http://code.google.com/p/postgis/issues/detail?id=67
> Comment #1 by mark.cav... at siriusit.co.uk:
> I guess that could be a useful feature; as a temporary work-around you
> could always
> use ALTER USER foo SET default_tablespace 'bar' and then load the
> shp2pgsql output as
> the foo user before reverting if required.
> ATB,
> Mark.
