[postgis-devel] AsGML & AsGeoJson patches
Courtin Olivier
olivier.courtin at camptocamp.com
Wed Nov 5 00:40:51 PST 2008
I've made a patch related to export function, inside it:
- AsGML
- Curve geometry nice error message
- GeometryCollection handle
- Code factorization between GML 2.1.2 and 3.1.1
- version parameter no more a a global one
- use decimal places rather than significants digits
(with doc update)
- trim trailing zero
- unit test file
AsGeoJson
- add forgotten pfree on subgeometry size process
- return geometry type name on error (i.e for curve)
Gml3 output was widely test, Gml2 a bit less
Patchs provided for 1.3 branches and trunk.
Enjoy !
FYI, Still on my Todo for theses export functions:
- SVG Unit Test
- KML decimal places
- Trunk doc improve
- RFC 5165 compliant (GML, GeoJson, KML also ?)
- GML3 Curve handle (low priority)
Olivier
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081105/724cd33a/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081105/724cd33a/attachment-0001.obj>
