[postgis-devel] Issue 69 in postgis: ST_Translate crashes when fed circular string
codesite-noreply at google.com
Fri Nov 7 22:52:40 PST 2008
Issue 69: ST_Translate crashes when fed circular string
http://code.google.com/p/postgis/issues/detail?id=69
Comment #5 by robe.... at cityofboston.gov:
Forgot I have yet to try with the other affine functions but I assume they
should
work. I'll try those in the next couple of days.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
