[postgis-devel] Issue 69 in postgis: ST_Translate crashes when fed circular string
codesite-noreply at google.com
Fri Nov 7 22:43:38 PST 2008
Issue 69: ST_Translate crashes when fed circular string
http://code.google.com/p/postgis/issues/detail?id=69
Comment #4 by robe.... at cityofboston.gov:
Works for me. Also tried with a simple collection and seems to work
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
