[postgis-devel] Issue 66 in postgis: ST_Dump kills backend when fed CIRCULAR STRING
codesite-noreply at google.com
Wed Nov 5 12:59:59 PST 2008
Issue 66: ST_Dump kills backend when fed CIRCULAR STRING
http://code.google.com/p/postgis/issues/detail?id=66
Comment #7 by robe.... at cityofboston.gov:
Hey Mark - I got it to work by making the fixes I mentioned above (3
locations as far
as I can tell). I'm going to test out with multicurves first and then
submit a patch
to you if all looks good. I would prefer you look over it when I am done
instead of
me just committing it since we are about to release.
Though I stuck with itemizing because I don't know the code base well
enough to
threaten doing anything more sophisticated especially so close to release.
Thanks,
Regina
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
