[postgis-devel] Issue 66 in postgis: ST_Dump kills backend when fed CIRCULAR STRING
codesite-noreply at google.com
Thu Nov 6 09:27:55 PST 2008
Issue 66: ST_Dump kills backend when fed CIRCULAR STRING
http://code.google.com/p/postgis/issues/detail?id=66
Comment #8 by mark.cav... at siriusit.co.uk:
Regina,
Your analysis was spot on. Since the same check is required in 3 separate
places, it
made sense to break it out into a separate function rather than keep
repeating the
code. I've committed the fix to both 1.3 branch and SVN trunk - please can
you test
at your end?
Many thanks,
Mark.
Issue attribute updates:
Status: Fixed
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
