[postgis-devel] 1.3.4 RC3
Obe, Regina
robe.dnd at cityofboston.gov
Fri Nov 14 05:42:09 PST 2008
FWIW, switching my 8.3 on OpenSUSE to run on the default port 5432
makes make check check the right version. So I guess make check is just
hard-coded to assume postgresql is on the default port and I presume
always been that way.
All checks pass with the Linux PostgreSQL binary EnterpriseDb 8.3.3
provided one-click install. I haven't tried with the 8.3.5 one-click
install, but assume it would work.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
