[postgis-devel] Issue 51 in postgis: Enhancement to ST_Summary to include info about invalid geometries
codesite-noreply at google.com codesite-noreply at google.com
Thu Nov 27 09:22:08 PST 2008
Comment #3 on issue 51 by pwramsey3: Enhancement to ST_Summary to include
http://code.google.com/p/postgis/issues/detail?id=51
(a) you need to 'svn up' your GEOS, make and make install it before you
compile your PostGIS
(b) don't forget that Mark changed the install location in 1.4 (I think we
might want to talk about it, it's a
potential nightmare) so that the "real" lwpostgis.sql is located in
share/contrib now, not a level lower. if you
install the lower you, you end up with a 1.3 database (since probably
that's what you put there)
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
