[postgis-devel] Issue 51 in postgis: Enhancement to ST_Summary to include info about invalid geometries
codesite-noreply at google.com
Thu Nov 27 09:56:12 PST 2008
Comment #4 on issue 51 by robe.... at cityofboston.gov: Enhancement to
http://code.google.com/p/postgis/issues/detail?id=51
Yap figured that out. I thought I had done that, but I guess I was
mistaken. I was
using the sites svn nightly build which normally works, but I guess your
changes were
too new that they hadn't hit that. Anyrate it compiles now.
Once I test out - I'll put an entry in the docs and note that its available
for
PostGIS 1.4+ and requires GEOS 3.1.0+ (emm why don't we have something on
GEOS 3.1.0
version info that denotes it hasn't been released yet.)
Thanks,
Regina
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
