[postgis-devel] Issue 51 in postgis: Enhancement to ST_Summary to include info about invalid geometries
codesite-noreply at google.com
Thu Nov 27 11:11:27 PST 2008
Updates:
Status: Fixed
Comment #5 on issue 51 by robe.... at cityofboston.gov: Enhancement to
http://code.google.com/p/postgis/issues/detail?id=51
Okay tested and documented. Also verified correctly throws an error rather
than
crashing when fed circular strings and also returns null when fed null.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
