[postgis-devel] Issue 51 in postgis: Enhancement to ST_Summary to include info about invalid geometries
codesite-noreply at google.com codesite-noreply at google.com
Fri Nov 28 01:45:15 PST 2008
Comment #6 on issue 51 by mark.cav... at siriusit.co.uk: Enhancement to
http://code.google.com/p/postgis/issues/detail?id=51
pramsey: Nice work - but unfortunately r3341 breaks the build for GEOS 3.0!
The fix
is to wrap the entire function in an #if POSTIGS_GEOS_VERSION.. #endif
section so
that it only gets compiled with GEOS >= 3.1. I'm fairly snowed under at the
moment,
so feel free to add this if you manage to get a chance.
About the lwpostgis.sql install location: this is handled automatically by
PGXS, so
it's not something we have direct control over :(  Then again, for me it
was a bugfix
anyway since the 1.3 hacked-up Makefiles always used to drop it in
/usr/share which
was totally wrong anyway...
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
