[postgis-devel] Issue 51 in postgis: Enhancement to ST_Summary toinclude info about invalid geometries
Obe, Regina
robe.dnd at cityofboston.gov
Fri Nov 28 04:33:03 PST 2008
Oh that's what I forgot to test. I was meaning to do that.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
codesite-noreply at google.com
Sent: Friday, November 28, 2008 4:45 AM
To: postgis-devel at postgis.refractions.net
Subject: [postgis-devel] Issue 51 in postgis: Enhancement to ST_Summary
Comment #6 on issue 51 by mark.cav... at siriusit.co.uk: Enhancement to
ST_Summary to include info about invalid geometries
http://code.google.com/p/postgis/issues/detail?id=51
pramsey: Nice work - but unfortunately r3341 breaks the build for GEOS
3.0!
The fix
is to wrap the entire function in an #if POSTIGS_GEOS_VERSION.. #endif
section so
that it only gets compiled with GEOS >= 3.1. I'm fairly snowed under at
the
moment,
so feel free to add this if you manage to get a chance.
About the lwpostgis.sql install location: this is handled automatically
by
PGXS, so
it's not something we have direct control over :( Then again, for me it
was a bugfix
anyway since the 1.3 hacked-up Makefiles always used to drop it in
/usr/share which
was totally wrong anyway...
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
