[postgis-devel] Do I need to worry about these warnings
Obe, Regina robe.dnd at cityofboston.gov
Fri Oct 3 04:34:27 PDT 2008
Finally decided to give the new 1.3.4SVN a test drive.  It compiles.
Haven't tried using it yet though, but I get the below warnings during
compile.  Do I need to worry about these?
lwgeom_geos_c.c
lwgeom_geos_c.c: In function 'GEOS2LWGEOM':
lwgeom_geos_c.c:2942: warning: assignment discards qualifiers from
pointer target type
lwgeom_geos_c.c:2951: warning: assignment discards qualifiers from
pointer target type
lwgeom_geos_c.c:2961: warning: assignment discards qualifiers from
pointer target type
lwgeom_geos_c.c:2962: warning: assignment discards qualifiers from
pointer target type
lwgeom_geos_c.c:2966: warning: assignment discards qualifiers from
pointer target type
lwgeom_geos_c.c:2967: warning: assignment discards qualifiers from
pointer target type
lwgeom_geos_c.c:2988: warning: assignment discards qualifiers from
pointer target type
lwgeom_geos_c.c: In function 'polygonize_garray':
lwgeom_geos_c.c:3352: warning: passing argument 1 of 'GEOSPolygonize'
from incompatible pointer type
lwgeom_geos_c.c: In function 'LWGEOM_buildarea':
lwgeom_geos_c.c:3502: warning: passing argument 1 of 'GEOSPolygonize'
lwgeom_geos_c.c:3545: warning: assignment discards qualifiers from
pointer target type
I'm running the below on openSUSE 10.3
"POSTGIS="1.3.4SVN" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
2007" USE_STATS"
I can't remember if I got this error before.  I don't think I was paying
too much attention if it compiled.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
