[postgis-devel] astyle
Kevin Neufeld kneufeld at refractions.net
Tue Oct 7 15:19:14 PDT 2008
Personally, I think it's a good idea to have a formatting standard (even
though I prefer the --style=kr :) ).  But I do echo Charlie's comment,
why not just reformat everything all at once?
It's too bad astyle doesn't support xml or xsl, because the
documentation could use a once over as well.
-- Kevin
Paul Ramsey wrote:
> If you've edited PostGIS source, you've quickly become frustrated with
> the ghastly mix of tabs and spaces used to format code. I would like
> to propose that we begin re-formatting the source incrementally, by
> making the use of
> astyle --style=ansi --indent=tab=8
> on any .c/.h files we are about to modify.
> - I'm about to modify foo.c!
> - astyle --style=ansi --indent=tab=8 foo.c
> - svn commit -m "Reformat!" foo.c
> - remember to set my editor to use tabs, not spaces, for block indents
> - Ok, make my changes now.
> Sound OK?
> Paul
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
