[postgis-devel] SQL comment generation
Kevin Neufeld
kneufeld at refractions.net
Fri Oct 10 10:02:10 PDT 2008
I have no problem with that - I think it's useful to have. If folks
want to load the extra sql file, at least the option is available to them.
-- Kevin
Obe, Regina wrote:
> Mark, Paul, Kevin et al,
> I think this got lost in the shuffle. Does any one have problems with me
> committing a postgis_comments.sql file to 1.3.4. I will take the
> responsibility of regenerating the .sql as the doc book changes are made
> and making sure the comments install on 1.3.4 build. I think we have a
> lot so far that would be very
> useful to people wading their way thru using PostGIS as a quick
> reference in the trenches. I can also tack it on in the
> instructions for 1.3.4 (after loading spatial_ref_sys.sql).
> For 1.4 yah probably makes sense to have it more integrated as part of
> the whole load
> process.
> Thanks,
> Regina
> -----Original Message-----
> From: Obe, Regina
> Sent: Sun 10/5/2008 4:47 PM
> To: PostGIS Development Discussion; PostGIS Development Discussion
> Subject: RE: [postgis-devel] SQL comment generation
> > I wonder if we should not do the #include in lwpostgis.sql.in.c for
> > spatial_ref_sys.sql in trunk too.
> Sorry to bore everyone with this when everyone is working on really
> important things.
> It just occurred to me the comments generated by the xsltproc work fine
> in postgis 1.3.4. Would anyone have an issue
> with me just committing it to 1.3.4 as a .sql file similar to
> spatial_ref_sys.sql and people can run it if they feel like it?
> As far as including in lwpostgis.sql.in.c in trunk, I haven't really
> explored that. The comments part makes sense, but I'm not convinced
> including the spatial_ref_sys.sql in the include is the right thing to
> do since many people fiddle with that table a lot, e.g. add new entries
> etc. I'm not sure the ramifications when you do a full dump and upgrade
> to a major version.
> Thanks,
> Regina
> * The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant
> to Massachusetts law. It is intended solely for the addressee. If you
> received this in error, please contact the sender and delete the
> material from any computer. *
> * Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper. *
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
