[postgis-devel] Recheck Considered Harmful (or, at least, Slow)
Paul Ramsey pramsey at cleverelephant.ca
Mon Oct 13 11:52:03 PDT 2008
I'd very much like to keep this in 1.3, unless we find something
requiring a larger patch to make it work. It's simple simple stuff and
so very effective. I think if testing bears it out, we should let it
stay.
And please, lets get that point release on the streets! :)
P.
On Mon, Oct 13, 2008 at 2:42 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paul Ramsey wrote:
>> A quick hack on LWGEOM_overlap to also use slicing takes the time for
>> my standard test case down further, from 4.9s to 3.7s.
>> So, to recap:
>> - old code, no prepare: 40s
>> - add prepared geom: 8s
>> - gist_consistent uses sliced detoast: 4.9s
>> - lwgeom_overlap uses sliced detoast: 3.7s
>> So, need to research a bit more into when bboxes are materialized, and
>> what cases would cause double de-toasting. I like your easy fix to the
>> point case, David.
>> P.
> Given that you've managed to make great strides in this area already, would
> it be possible to move this development just to SVN trunk? I'd really like
> to hope that 1.3.4 is last release in the 1.3 series, and I'm a little
> nervous about making changes to one of the core operators this close to a
> release. I think people would be more than happy with the improvements
> you've already made :)
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
