[postgis-devel] 1.4 SVN Compile problems
Obe, Regina
robe.dnd at cityofboston.gov
Tue Oct 14 04:05:28 PDT 2008
Mark,
This sounds great. I wasn't so much concerned about package
maintainers, but more people like me who don't want to be bothered with
compiling
PostgreSQL from source and get their PostgreSQL from repository but want
the latest and greatest PostGIS which the package maintainer is usually
one version behind or doesn't have the ideal set of Geos/Proj.
Sounds like your fix will solve that issue at anyrate.
Let me know when you have in place and I'll test again. For now I'm
testing the postgis 1.3.4 SVN which compiles fine and doesn't have the
dependency issue.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Tuesday, October 14, 2008 4:52 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] 1.4 SVN Compile problems
Obe, Regina wrote:
> Mark,
> So I take it this is a problem a lot of people will run into that get
> RPM installs, apt-get, Yum, etc. I hate to say it, but thats a lot of
> people these days. Mine I didn't compile. It came via the OpenSUSE
> repository thingy.
> Seems like we should explain it somewhere in the docs. Though I'm not
> skilled enough to do this since
> I can barely flounder my way thru Linux as it is. But I am getting
> better though :)
> Thanks,
> Regina
Hi Regina,
I had a look at this and discovered that there is a better way of doing
this - the problem is that I used the flags variable from the old 1.3
build system when in fact there is a separate one just for linking
against libpq. In terms of dependencies, that's not too much of an issue
as these can be handled automatically by the package maintainers - but
I'm fairly sure I can remove most of these new dependencies.
I'll commit a fix for this later, although my SVN tree currently has a
massive WIP parser changeset for trunk which I need to finish first...
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
