[postgis-devel] More harping about questionable 3D
Obe, Regina
robe.dnd at cityofboston.gov
Fri Oct 17 08:25:01 PDT 2008
Okay I'm beginning to question the benefit of these sort of 3D hacks.
In some cases it makes sense but for ST_Difference? Really
SELECT ST_AsEWKT(ST_Difference(ST_GeomFromEWKT('MULTIPOINT(-118.58 38.38
5,-118.60 38.329 6,-118.614 38.281 7)'), ST_GeomFromEWKT('POINT(-118.614
38.281 5)')));
st_asewkt
MULTIPOINT(-118.6 38.329 6,-118.58 38.38 5)
Martin I think I was wrong about all of GEOS having these blue smurf
code gifts. I think some of these may actually be in the PostGIS
code-base. I'll need to trace the code closer though to determine the
root of this smurfiness, unless per chance someone knows.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
