[postgis-devel] Issue 48 in postgis: Broken scroll cursors with gist index
codesite-noreply at google.com codesite-noreply at google.com
Sat Oct 18 00:34:51 PDT 2008
Issue 48: Broken scroll cursors with gist index
http://code.google.com/p/postgis/issues/detail?id=48
Comment #2 by mark.cav... at siriusit.co.uk:
Martin,
Please see the follow-up here:
http://archives.postgresql.org/pgsql-hackers/2008-10/msg00855.php
Note that it looks as if the relevant fixes have been applied to CVS, but
only for
8.4 devel and so it is unlikely this well get backpatched :(  I would
suggest that
you download an 8.4 CVS, test, and make sure it works as you would expect.
ATB,
Mark.
Issue attribute updates:
	Status: Started
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
