[postgis-devel] SVN trunk parser modifications stage 2
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Sat Oct 18 00:55:47 PDT 2008
Hi everyone,
Now that the new parser API is in place, I'd like to discuss how we can
control its behaviour from within PostGIS/PostgreSQL. Normally the
parser is very strict in terms of validating input geometries, however
there have been a few documented cases where it is necessary to load
invalid data into the database in order for it to be cleaned up.
I would like to propose that the parser behaviour can be toggled using a
set of in-built stored procedures similar to below:
The documented API:
SELECT postgis_disable_parser_checks()
- This will disable ALL checks performed by the parser for the
remaining duration of the connection. This will throw a very
large WARNING to let you know that what you are doing can will
potentially allow bad data into the database and that its
effects only last for the duration of the session.
SELECT postgis_enable_parser_checks()
- This will re-enable ALL checks performed by the parser. Note
that all checks enabled will remain the default.
The undocumented API:
SELECT postgis_parser_checks(int, int)
- This will allow advanced developers the ability to specify the
parser checks as 2 bitmaps: 1 for incoming geometries, and 1 for
outgoing geometries (those generated by GEOS). It is designed
for use and testing by developers only.
Note that I have deliberately named these functions so that they are in
the postgis_ namespace rather than the ST_ namespace, and so developers
should be well aware that what they are doing is definitely outside of
the OGC specification and that its behaviour is unique to PostGIS.
Once these changes have been committed, the final stage of the plan is
to move shp2pgsql/pgsql2shp over to use liblwgeom and the new stored
procedures (adding something like a --force option to trigger this
behaviour).
Thoughts?
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
