[postgis-devel] 1.3.4rc1
Obe, Regina robe.dnd at cityofboston.gov
Mon Oct 20 08:00:08 PDT 2008
Greg,
What's dragon fly? by the way I updated the README in both trunk and
branch.  Maybe we should have an RC2?
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Greg
Troxel
Sent: Monday, October 20, 2008 10:35 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] 1.3.4rc1
  The PostGIS team is pleased to provide release version 1.3.4rc1 for
  your testing delectation.
  You may download it from:
  http://postgis.refractions.net/download
I dropped that version into pkgsrc (but am not committing it), and built
against geos 3.0.2, proj 4.6.0, and pgql 8.1.14 on NetBSD/i386
4.0_STABLE.
The patch at the end of this mail is in pkgsrc to add dragonfly support
and it would be nice to apply it upstream, although I realize it is the
11th hour.
The rc1 tarball unpacked into postgis-1.3.4svn instead of the expected
postgis-1.3.4rc1.
I tried to run make check before installing postgis, and that failed
immediately, but README.postgis implies it should work.  After
installing, make check succeeded.  I do not understand how pre-install
make check could work, so perhaps this is just a documentation buglet.
patch:
$NetBSD: patch-aa,v 1.3 2006/12/06 17:43:27 joerg Exp $
--- lwgeom/Makefile.shlib.orig	2006-12-06 17:36:49.000000000 +0000
+++ lwgeom/Makefile.shlib
@@ -140,6 +140,10 @@ ifeq ($(PORTNAME), freebsd)
   endif
 endif
+ifeq ($(PORTNAME), dragonfly)
+  LINK.shared		= $(COMPILER) -shared -Wl,-x,-soname,$(soname)
+endif
 ifeq ($(PORTNAME), netbsd)
   ifdef ELF_SYSTEM
make test log with postgis not installed:
gdt 105 /usr/pkgsrc/geography/postgresql81-postgis > make test
=> Bootstrap dependency digest>=20010302: found digest-20080510
===> Testing for postgresql81-postgis-1.3.4rc1
Using GNU make found at
/n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/.tools
/bin/gmake
gmake[1]: Entering directory
`/n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/postg
is-1.3.4svn'
/bin/gmake -C regress test
gmake[2]: Entering directory
is-1.3.4svn/regress'
Creating spatial db postgis_reg
ERROR:  function postgis_lib_version() does not exist
HINT:  No function matches the given name and argument types. You may
need to add explicit type casts.
 Something went wrong (no postgis installed in postgis_reg).
 For details, check /tmp/pgis_reg_15161/regress_log
gmake[2]: *** [test] Error 1
gmake[2]: Leaving directory
gmake[1]: *** [check] Error 2
gmake[1]: Leaving directory
is-1.3.4svn'
gmake: *** [check] Error 2
*** Error code 2
Stop.
make: stopped in
*** Error code 1
Stop.
make: stopped in /usr/pkgsrc/geography/postgresql81-postgis
/tmp/pgis_reg_15161/regress_log:
CREATE DATABASE
BEGIN
psql:lwpostgis.sql:44: NOTICE:  type "histogram2d" is not yet defined
DETAIL:  Creating a shell type definition.
psql:lwpostgis.sql:44: ERROR:  could not access file
"/usr/pkg/lib/liblwgeom": No such file or directory
psql:lwpostgis.sql:50: ERROR:  current transaction is aborted, commands
ignored until end of transaction block
psql:lwpostgis.sql:56: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:62: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:70: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:88: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:94: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:100: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:106: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:113: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:131: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:137: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:143: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:149: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:156: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:162: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:170: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:176: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:182: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:188: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:204: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:215: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:221: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:228: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:234: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:241: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:247: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:254: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:260: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:267: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:273: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:280: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:286: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:292: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:298: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:304: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:310: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:317: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:323: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:330: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:336: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:344: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:351: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:358: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:364: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:382: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:388: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:394: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:400: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:407: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:413: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:419: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:425: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:431: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:437: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:443: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:449: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:455: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:461: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:467: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:473: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:479: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:497: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:503: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:509: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:515: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:523: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:542: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:548: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:554: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:560: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:567: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:575: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:581: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:587: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:593: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:599: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:605: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:611: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:617: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:623: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:629: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:635: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:641: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:647: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:653: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:659: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:665: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:671: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:677: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:690: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:696: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:702: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:708: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:714: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:720: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:726: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:732: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:738: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:744: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:750: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:756: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:766: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:772: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:778: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:784: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:789: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:800: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:816: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:826: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:838: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:850: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:856: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:862: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:868: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:874: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:880: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:886: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:892: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:898: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:904: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:910: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:916: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:922: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:928: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:934: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:940: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:946: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:952: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:958: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:964: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:970: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:976: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:982: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:988: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:994: ERROR:  current transaction is aborted, commands
psql:lwpostgis.sql:1002: ERROR:  current transaction is aborted,
commands ignored until end of transaction block
psql:lwpostgis.sql:1008: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1014: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1020: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1026: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1032: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1038: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1044: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1050: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1056: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1062: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1068: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1081: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1086: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1091: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1096: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1101: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1106: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1111: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1142: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1151: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1164: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1170: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1176: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1182: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1188: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1194: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1200: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1206: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1216: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1222: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1228: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1234: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1240: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1246: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1252: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1258: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1264: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1270: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1276: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1282: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1288: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1294: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1300: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1310: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1316: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1322: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1328: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1334: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1340: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1346: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1352: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1364: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1370: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1376: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1382: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1387: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1393: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1401: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1407: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1413: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1419: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1425: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1431: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1439: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1445: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1451: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1457: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1463: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1469: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1477: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1484: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1490: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1496: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1502: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1508: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1514: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1520: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1527: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1533: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1540: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1546: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1552: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1558: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1564: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1570: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1580: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1586: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1592: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1598: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1605: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1611: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1617: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1623: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1629: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1635: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1641: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1647: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1653: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1659: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1665: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1671: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1677: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1683: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1690: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1697: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1703: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1709: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1716: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1723: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1729: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1735: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1743: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1752: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1758: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1764: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1770: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1776: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1782: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1788: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1794: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1800: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1806: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1812: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1818: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1824: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1830: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1836: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1842: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1848: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1854: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1860: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1866: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1872: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1878: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1884: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1890: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1896: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1902: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1908: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1914: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1920: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1926: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1932: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1938: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1944: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1950: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1956: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1962: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1968: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1978: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1984: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1990: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:1996: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2002: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2008: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2014: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2020: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2026: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2032: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2038: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2044: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2050: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2056: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2062: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2068: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2074: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2080: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2086: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2092: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2098: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2104: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2110: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2116: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2122: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2128: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2136: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2144: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2150: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2156: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2162: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2168: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2174: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2180: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2186: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2192: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2198: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2204: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2212: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2220: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2223: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2229: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2235: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2241: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2247: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2260: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2266: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2273: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2280: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2286: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2292: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2299: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2306: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2319: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2325: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2334: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2340: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2357: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2368: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2378: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2384: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2393: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2399: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2407: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2412: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2420: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2425: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2445: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2462: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2482: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2498: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2509: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2527: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2543: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2652: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2746: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2923: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2941: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:2959: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3031: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3053: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3075: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3120: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3132: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3145: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3233: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3249: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3265: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3279: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3293: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3332: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3345: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3352: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3357: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3363: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3372: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3376: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3386: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3390: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3395: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3399: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3403: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3407: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3411: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3415: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3467: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3477: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3483: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3489: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3495: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3501: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3507: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3513: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3519: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3525: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3531: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3537: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3543: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3549: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3555: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3562: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3568: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3574: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3580: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3586: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3592: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3598: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3604: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3610: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3616: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3622: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3628: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3634: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3640: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3646: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3649: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3650: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3651: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3652: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3653: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3654: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3655: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3656: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3657: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3658: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3659: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3660: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3661: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3672: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3678: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3685: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3691: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3698: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3704: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3711: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3717: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3724: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3730: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3736: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3742: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3752: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3758: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3764: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3770: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3776: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3782: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3788: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3794: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3800: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3806: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3816: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3822: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3828: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3834: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3840: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3846: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3852: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3858: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3865: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3871: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3877: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3883: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3889: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3895: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3901: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3907: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3913: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3919: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3925: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3932: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3939: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3945: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3951: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3959: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3967: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3973: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3979: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3985: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3991: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:3997: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4003: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4009: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4015: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4022: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4028: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4034: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4040: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4046: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4053: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4058: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4064: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4071: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4077: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4083: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4090: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4096: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4102: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4109: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4115: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4121: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4127: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4134: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4141: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4147: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4154: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4160: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4167: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4173: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4179: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4185: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4191: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4197: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4203: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4209: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4215: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4221: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4227: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4233: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4239: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4249: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4255: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4261: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4267: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4273: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4279: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4288: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4295: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4301: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4308: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4314: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4321: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4328: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4337: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4344: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4350: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4357: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4364: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4370: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4377: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4384: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4394: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4400: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4406: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4412: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4418: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4424: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4430: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4441: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4447: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4453: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4459: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4465: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4471: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4477: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4483: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4489: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4495: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4501: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4507: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4513: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4519: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4525: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4531: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4537: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4564: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4570: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4576: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4582: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4588: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4594: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4600: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4606: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4612: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4618: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4624: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4630: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4636: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4642: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4648: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4654: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4660: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4666: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4672: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4678: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4684: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4690: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4696: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4702: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4708: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4714: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4720: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4726: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4732: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4738: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4744: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4750: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4756: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4762: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4767: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4772: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4777: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4782: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4792: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4802: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4812: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4823: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4833: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4843: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4853: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4863: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4869: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4875: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4885: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4895: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4905: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4915: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4921: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4927: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4933: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4939: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4950: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4961: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4971: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4981: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4987: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4993: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:4999: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5005: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5015: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5025: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5035: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5045: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5051: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5057: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5063: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5069: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5075: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5085: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5095: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5105: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5115: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5121: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5127: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5133: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5139: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5150: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5161: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5172: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5183: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5189: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5195: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5201: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5207: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5217: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5227: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5237: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5247: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5257: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5267: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5277: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5287: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5297: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5307: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5317: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5327: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5337: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5347: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5357: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5367: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5377: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5387: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5397: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5407: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5417: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5427: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5437: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5447: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5457: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5467: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5477: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5487: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5497: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5507: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5517: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5527: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5537: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5547: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5557: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5567: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5577: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5587: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5597: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5607: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5617: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5627: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5637: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5647: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5658: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5669: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5680: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5691: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5734: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5763: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5799: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5823: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5867: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5918: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5925: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5932: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5939: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:5972: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6005: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6012: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6017: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6022: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6081: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6099: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6144: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6203: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6223: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6280: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6303: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6317: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6331: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6345: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6351: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6357: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6395: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6444: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6467: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6473: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6497: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6508: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6513: ERROR:  current transaction is aborted,
psql:lwpostgis.sql:6518: ERROR:  current transaction is aborted,
ROLLBACK
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
