[postgis-devel] RE: [postgis-commits] svn - r3187 - trunk/doc
Obe, Regina
robe.dnd at cityofboston.gov
Mon Oct 27 04:38:53 PDT 2008
Kevin,
Any plans to commit this to 1.3 branch. I guess its nearing close to
release, but I don't personally see a problem with doing so if the
higher ups (Mark and Paul) don't and would make my life easier, since
now if I update the postgis_comments.sql for 1.3.4, I have to strip this
function out since I generate it from the 1.4 docs.
Anyrate you should put in an Availability notice in the docs and
lwpostgis.sql.in.c since its a new function.
Thanks,
Regina
-----Original Message-----
From: postgis-commits-bounces at postgis.refractions.net
[mailto:postgis-commits-bounces at postgis.refractions.net] On Behalf Of
postgis-commits at postgis.refractions.net
Sent: Monday, October 27, 2008 2:30 AM
To: postgis-commits at postgis.refractions.net
Subject: [postgis-commits] svn - r3187 - trunk/doc
Author: kneufeld
Date: 2008-10-26 23:29:42 -0700 (Sun, 26 Oct 2008)
New Revision: 3187
trunk/doc/reference_new.xml
updated description for Populate_Geometry_Columns
Modified: trunk/doc/reference_new.xml
--- trunk/doc/reference_new.xml 2008-10-27 06:13:35 UTC (rev 3186)
+++ trunk/doc/reference_new.xml 2008-10-27 06:29:42 UTC (rev 3187)
@@ -820,11 +820,10 @@
<title>Description</title>
<para>Ensures geometry columns have appropriate spatial
constraints and
- exist in the <varname>geometry_columns</varname> table.</para>
+ exist in the <varname>geometry_columns</varname> table. In
particular,
+ this means that every geometry column belonging to a table has
at least
+ three constraints:</para>
- <para>In particular, this means that every geometry column
belonging to a
- table has at least three constraints:</para>
<itemizedlist>
<listitem>
<para><varname>enforce_dims_the_geom</varname> - ensures
every
@@ -845,21 +844,27 @@
</listitem>
</itemizedlist>
- <para>If a table oid is provided, this function tries to
determine the
- srid, dimension, and geometry type of all geometry columns in
the table,
- adding contraints as necessary. If successful, an appropriate
row is
- inserted into the geometry_column table, otherwise, the
exception is
- caught and an error notice is raised describing the
problem.</para>
+ <para>If a table <varname>oid</varname> is provided, this
function
+ tries to determine the srid, dimension, and geometry type of
all
+ geometry columns in the table, adding contraints as necessary.
if
+ successful, an appropriate row is inserted into the
geometry_column
+ table, otherwise, the exception is caught and an error notice
is raised
+ describing the problem.</para>
- <para>If an oid of a view is provided, as with a table oid,
this function
- tries to determine the srid, dimension, and type of all the
geometries in
- the view, inserting appropriate entries into the
geometry_columns table,
- but nothing is done to enforce contraints.</para>
+ <para>If the <varname>oid</varname> of a view is provided, as
with a
+ table oid, this function tries to determine the srid,
dimension, and
+ type of all the geometries in the view, inserting appropriate
entries
+ into the <varname>geometry_columns</varname> table, but nothing
is done
+ to enforce contraints.</para>
<para>The parameterless variant is a simple wrapper for the
parameterized
variant that first truncates and repopulates the
for every spatial table and view in the database, adding
spatial
- contraints to tables where appropriate.</para>
+ contraints to tables where appropriate. It returns a summary
of the
+ number of geometry columns detected in the database and the
number that
+ were inserted into the <varname>geometry_columns</varname>
table. The
+ parameterized version simply returns the number of rows
inserted into
+ the <varname>geometry_columns</varname> table.</para>
</refsection>
<refsection>
postgis-commits mailing list
http://lists.refractions.net/mailman/listinfo/postgis-commits
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
