[postgis-devel] ESRI link to docs
Obe, Regina
robe.dnd at cityofboston.gov
Tue Sep 9 22:09:09 PDT 2008
I just noticed ESRI has a link to the PostGIS docs. Kind of heart-warming. Too bad the link to the pdf gives a 404. Perhaps we should fix that.
http://webhelp.esri.com/arcgisserver/9.3/java/index.htm#geodatabases/using_th485132809.htm
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20080910/ef8a2bda/attachment.html>
