[postgis-devel] Re: [postgis-users] PDF version of manual?
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Thu Sep 11 08:59:08 PDT 2008
Kevin Neufeld wrote:
> Great. Thanx Mark.
> Curious. <inlinegraphic> is not a DocBook standard?
Ah. I probably should have been a bit clearer in my original email - not
the <inlinegraphic> element itself, just the "class" attribute which had
been added to the element within the PostGIS documentation. (Although as
you quite rightly point out, it is deprecated in v5).
> You mentioned you tried xmlroff to generate the pdf but it didn't fair
> well. Previously, Paul generated his nice version that closely matches
> the new html stylesheet using XSL-FO and Adobe Fop. I haven't been able
> to reproduce that yet though.
I did have a quick look at FOP, but then got cold feet when I realised
I'd have to install a load of Java packages at the same time. Hence the
quick fix of putting the OpenJade system back into place, so at least
there is something to work with until someone can come up with something
better (if applicable) ;)
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
