[postgis-devel] Re: [postgis-users] PDF version of manual?
Paul Ramsey
pramsey at cleverelephant.ca
Thu Sep 11 09:45:30 PDT 2008
Generating the pdf is a sufficiently specialized operation that it
doesn't matter if it depends on FOP. Once kevin gets it working, he
can set it up to auto-run on the rackmount and then noone else will
care :)
P
On Thu, Sep 11, 2008 at 8:59 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Kevin Neufeld wrote:
>> Great. Thanx Mark.
>> Curious. <inlinegraphic> is not a DocBook standard?
> Ah. I probably should have been a bit clearer in my original email - not the
> <inlinegraphic> element itself, just the "class" attribute which had been
> added to the element within the PostGIS documentation. (Although as you
> quite rightly point out, it is deprecated in v5).
>> You mentioned you tried xmlroff to generate the pdf but it didn't fair
>> well. Previously, Paul generated his nice version that closely matches the
>> new html stylesheet using XSL-FO and Adobe Fop. I haven't been able to
>> reproduce that yet though.
> I did have a quick look at FOP, but then got cold feet when I realised I'd
> have to install a load of Java packages at the same time. Hence the quick
> fix of putting the OpenJade system back into place, so at least there is
> something to work with until someone can come up with something better (if
> applicable) ;)
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
