[postgis-devel] Minimum number of points in a POLYGON ring?
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Sep 19 08:12:36 PDT 2008
Kevin Neufeld wrote:
> My my readings, according to OGC, the number of points is vague, but the
> ruleset is specific. A Polygon is made up of a set of LinearRings
> (following a set of rules about how they relate to eachother). A
> LinearRing is a LineString that is both closed (startpoint ~= endpoint)
> and simple (does not self-intersect). This implies that a linear ring
> must be made up of at least 4 points (3 distinct points) to avoid
> self-intersection.
> So the parser check should probably be increased the check to 4, but
> making sure the endpoints are equal (thus 3 distinct points).
> Does that help?
Yes thanks, that was my interpretation of the specification too. However
please see my reply to Paul's thoughts on loosening the parser checks -
I'll leave things as they are for the moment until we can come up with
some form of consensus as to which way we should go.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
