[postgis-devel] Issue 35 in postgis: Comments on Postgis Functions
codesite-noreply at google.com
Mon Sep 22 05:37:25 PDT 2008
Issue 35: Comments on Postgis Functions
http://code.google.com/p/postgis/issues/detail?id=35
Comment #3 by robe.... at cityofboston.gov:
Committed xsl file to new doc/xsl folder that autogenerates sql comment
insert
statements using current reference_new.xml. Has not been integrated into
build.
Waiting for Mark to approve. Only relies on xsltproc so no python
dependency.
Eventually will try to integrate Dane's sql help module to show extended
help.
Issue attribute updates:
Status: Started
Owner: robe.... at cityofboston.gov
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
