[postgis-devel] Issue 42 in postgis: Postgis Docbook CSS upgrade
codesite-noreply at google.com codesite-noreply at google.com
Mon Sep 22 07:30:16 PDT 2008
Issue 42: Postgis Docbook CSS upgrade
http://code.google.com/p/postgis/issues/detail?id=42
Comment #2 by dane.springmeyer:
Yes, I'd be more than happy to make further adjustments, but it seems like
it worked well enough to be added
without significant changes. I think that Kevin caught a problem with fonts
by making the code preformatted
text monospace, and that was it.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
