[postgis-devel] Issue 35 in postgis: Comments on Postgis Functions
codesite-noreply at google.com
Mon Sep 22 09:12:18 PDT 2008
Issue 35: Comments on Postgis Functions
http://code.google.com/p/postgis/issues/detail?id=35
Comment #6 by ke... at refractions.net:
Yeah, I got the same error using xsltproc. Changing the second line to
version 1.0
solved the compile problem for me.
-- Kevin
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
