[postgis-devel] Re: [postgis-users] PostGIS PDF using dblatex/pdflatex
Paul Ramsey pramsey at cleverelephant.ca
Mon Sep 22 11:02:08 PDT 2008
I'm not set on anything. :)
P
On Mon, Sep 22, 2008 at 10:50 AM, Kevin Neufeld
<kneufeld at refractions.net> wrote:
> Very nicely done David.
> PaulR - are you really set on producing a PDF via Apache's FOP?  This looks
> far better than anything I've been able to reproduce with FOP or Docbook's
> db2pdf.
> David, what exactly is your command line for generating the doc (maybe I can
> put it in the autobuild process that gets updated on every SVN commit)?
>  Assuming of course that folks are ok with adding a new dependency with the
> build process ...
> Cheers,
> Kevin
> Jean David TECHER wrote:
>> Dear all,
>> I've tried to compil the postgis.pdf using the svn tarball.
>> The output is available at
>> http://www.davidgis.fr/postgis-out.pdf
>> AFAIK, the output seems to be beautifull since you can see the images.
>> Hope these help people for a printing solution for postgis doc  ;)
>> --david;
>> Jean David TECHER
>> www.davidgis.fr
>> 06 60 46 85 05
>> 04 99 77 16 87
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
