[postgis-devel] ST_MakePointM?
Obe, Regina
robe.dnd at cityofboston.gov
Wed Sep 24 03:58:49 PDT 2008
Nudge Nudge Mark,
I take it from your silence if I define this function in just
lwpostgis.sql.in.c in 1.3.4 and 1.4 and make the docs not a liar - it
won't cause you or anyone else any problems?
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Obe,
Regina
Sent: Tuesday, September 23, 2008 9:37 AM
To: PostGIS Development Discussion
Subject: [postgis-devel] ST_MakePointM?
The docs refer to a function named - ST_MakePointM
http://postgis.refractions.net/documentation/manual-svn/ch06.html#id2722
518
I don't see this in my 1.3.4 install and don't see it in the 1.4 source.
It appears to be an oversight since there is a deprecated MakePointM but
no equivalent
ST_MakePointM I can find.
Anyone have any objections to me adding this to the lwpostgis.sql.in.c
I presume it doesn't need to go anywhere else.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
