[postgis-devel] Issue 21 in postgis: locate_along_measure: wrong values, invalid data ?
codesite-noreply at google.com codesite-noreply at google.com
Thu Sep 25 01:29:09 PDT 2008
Issue 21: locate_along_measure: wrong values, invalid data ?
http://code.google.com/p/postgis/issues/detail?id=21
Comment #12 by l... at rosinak.at:
Hi Mark,
my solution passes the regression tests, your solution modifies the results.
select 'LINEZM_6',
asewkt(locate_between_measures('LINESTRING(0 10 10 40, 10 0 0 0)', 2, 2));
result as expected and with my solution
LINEZM_6|POINT(9.5 0.5 0.5 2)
result with your solution
LINEZM_6|LINESTRING(9.5 0.5 0.5 2,9.5 0.5 0.5 2)
i didn't find the specification of the semantics, so i can't decide what is
the correct
result. The POINT(...) result makes more sense for me.
However, I hope that any solution is making it into to the next release
code, because
a core dumping RDBMS isn't the thing i want rely on - i assume we can agree
on this.
I attached a patch with some additional regression tests.
Kind regards,
Richard
	regression_issue-21-patch.diff  2.6 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
