[postgis-devel] Issue 21 in postgis: locate_along_measure: wrong values, invalid data ?
codesite-noreply at google.com codesite-noreply at google.com
Thu Sep 25 02:51:24 PDT 2008
Issue 21: locate_along_measure: wrong values, invalid data ?
http://code.google.com/p/postgis/issues/detail?id=21
Comment #13 by mark.cav... at siriusit.co.uk:
Hi Richard,
I'm afraid I don't see that result here at all. Here are my results using
SVN PostGIS
1.3 branch:
Current behaviour:
postgis13=# select asewkt(st_locate_along_measure(ST_GeomFromEWKT('
SRID=31293;LINESTRINGM(
6193.76 5337404.95 4519,
6220.13 5337367.145 4566,
6240.889 5337337.383 4603
)'), 4566));
                                           asewkt
  SRID=31293;MULTIPOINTM(1.99915902736236e+37 -1.05616313798637e+45
5.41519507362328e-315,)
(1 row)
postgis13=# select 'LINEZM_6',
asewkt(locate_between_measures('LINESTRING(0 10 10 40, 10 0 0 0)', 2, 2));
  ?column? |        asewkt
  LINEZM_6 | POINT(9.5 0.5 0.5 2)
(1 row)
Behaviour with attached patch:
)'), 4566));
                    asewkt
  SRID=31293;POINTM(6220.13 5337367.145 4566)
(1 row)
  ?column? |        asewkt
(1 row)
Furthermore with the same patch I see the same results for your extra
regression tests:
postgis13=# select 'LINEZM_7', asewkt(locate_between_measures('LINESTRING(0
0 0 0, 1
1 1 1, 2 2 2 2, 3 4 5 6)', 1, 2));
  ?column? |           asewkt
  LINEZM_7 | LINESTRING(1 1 1 1,2 2 2 2)
(1 row)
postgis13=# select 'LINEZM_8', asewkt(locate_between_measures('LINESTRING(0
0 0 0, 1
1 1 1, 2 2 2 2, 3 4 5 6)', 1.1, 2.1));
  ?column? |                          asewkt
  LINEZM_8 | LINESTRING(1.1 1.1 1.1 1.1,2 2 2 2,2.025 2.05 2.075 2.1)
(1 row)
postgis13=# select 'LINEZM_9', asewkt(locate_between_measures('LINESTRING(0
0 0 0, 1
1 1 1, 2 2 2 2, 3 4 5 6)', 2, 2));
  ?column? |     asewkt
  LINEZM_9 | POINT(2 2 2 2)
(1 row)
postgis13=# select 'LINEPZM_1', asewkt(locate_along_measure('LINESTRING(0 0
0 0, 1 1
1 1, 2 2 2 2, 3 4 5 6)', 0));
  ?column?  |     asewkt
  LINEPZM_1 | POINT(0 0 0 0)
(1 row)
postgis13=# select 'LINEPZM_2', asewkt(locate_along_measure('LINESTRING(0 0
0 0, 1 1
1 1, 2 2 2 2, 3 4 5 6)', 1));
  ?column?  |     asewkt
  LINEPZM_2 | POINT(1 1 1 1)
(1 row)
postgis13=# select 'LINEPZM_3', asewkt(locate_along_measure('LINESTRING(0 0
0 0, 1 1
1 1, 2 2 2 2, 3 4 5 6)', 1.5));
  ?column?  |         asewkt
  LINEPZM_3 | POINT(1.5 1.5 1.5 1.5)
(1 row)
So I'm really confused as to why your results don't match mine?!
ATB,
Mark.
	lwgeom_functions_lrs.patch  631 bytes
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
