[postgis-devel] Re: r3014 regress
Paul Ramsey
pramsey at cleverelephant.ca
Sat Sep 27 07:56:42 PDT 2008
On Sat, Sep 27, 2008 at 1:40 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paul Ramsey wrote:
> Hmmm - it works fine here, although I guess Apple have different rules about
> visibility of non-extern symbols within a library. I've renamed the unparser
> flag in SVN so this should now work for you.
Thanks, that did it, back in business on OS/X.
> Incidentally although I've not really been involved in the PiP analysis, are
> you planning to do a before/after analysis on your blog? Would be
> interesting to see what improvements your work has brought in.
Sure. I've been thinking I should take the time and back-port it into
1.3, since the old, memory leaking version exists there (as found by
Kevin), which is a bad thing to leave in the "stable" version.
P
