[postgis-devel] Port Issues Google => Trac
Paul Ramsey
pramsey at opengeo.org
Wed Apr 1 14:53:41 PDT 2009
If anyone wants to take a try at porting issues to Trac, the Google
data is here now:
http://cleverelephant.dyndns.org/~pramsey/postgis-issues.xml
Not well-formed XML, the stuff between description tags isn't escaped,
be warned. If you want to use a real XML parser on it, let me know and
I'll generate that stuff inside CDATA blocks.
Howard says the way to do it is to get a blank trac instance running,
then take that SqlLite database and start inserting into it. Then you
can review your progress / success by using your trac instance to
explore the data.
Paul
