[postgis-devel] Port Issues Google => Trac
Paragon Corporation
lr at pcorp.us
Wed Apr 1 15:57:53 PDT 2009
Paul,
If its not too much trouble Cdata tags would be a bit better. Would save me
the trouble of trying to well-form it so my XSLT can deal with it.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Wednesday, April 01, 2009 5:54 PM
To: PostGIS Development Discussion
Subject: [postgis-devel] Port Issues Google => Trac
If anyone wants to take a try at porting issues to Trac, the Google data is
here now:
http://cleverelephant.dyndns.org/~pramsey/postgis-issues.xml
Not well-formed XML, the stuff between description tags isn't escaped, be
warned. If you want to use a real XML parser on it, let me know and I'll
generate that stuff inside CDATA blocks.
Howard says the way to do it is to get a blank trac instance running, then
take that SqlLite database and start inserting into it. Then you can review
your progress / success by using your trac instance to explore the data.
Paul
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
