[postgis-devel] Port Issues Google => Trac
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Apr 7 02:43:30 PDT 2009
Paragon Corporation wrote:
> Paul,
> Thanks -- this xml file looks good. So I'll give it a stab trying to
> convert to Trac SQLite format once I have my Trac install up and running.
> And then if I get that far I pull the attachment files from the urls.
> I assume Trac either keeps those in an sql blob in SQLite or on the file
> system somewhere.
> Thanks,
> Regina
Okay, how are we doing with the Trac migation - do we need spend some
coding time to get this done?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
