[postgis-devel] Issue 148 in postgis: st_touches doesn't work as it should on st_touches(line,point)
codesite-noreply at google.com
Wed Apr 8 05:13:45 PDT 2009
Status: New
Owner: ----
New issue 148 by post... at jordogskog.no: st_touches doesn't work as it
http://code.google.com/p/postgis/issues/detail?id=148
What steps will reproduce the problem?
I get false from st_touches if the point isn't the first or the last point
of the line.
SELECT ST_Touches('LINESTRING(0 0, 1 1, 0 2)'::geometry, 'POINT(1
1)'::geometry);
gives false, but from may understanding it should return true
SELECT ST_Touches('LINESTRING(0 0, 1 1, 0 2)'::geometry, 'POINT(0
0)'::geometry);
returns true as it should.
The result I get is the same as in the documentation for 1.4 so I get a
little confused, beacause I don't understand the behavior.
I have tried at 8.3 1.36 geos 3.03 and 8.3 1.4 geos 3.1.0
/Nicklas Avén
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
